17 years ago
Kernel mode Driver
Hi to all,
I am facing Problem regarding the quartus programmer. when i going to add hardware it doesnot show "lpt1" instead of that it is showing "kernel mode driver is not installed".
i have purchased the new PC which does not have parallel port installed in it, thus i have added a pci based parallel port card and installed the respected driver for it.
kindly help me to get rid of this situation
Warm Regards
Preet
    Hello, everybody.
    I have the same problem.
    As well as Preet i am using a PCI-based Parallel Port Card. I was able to connect a parallel printer to it (LPT1) and i was also able print with it.
    So principially the parallel port is working fine.
    In my mind the installation of the "Altera Byte Blaster" driver may be the basic problem. I followed the installation instructions on
    http://www.altera.com/support/software/drivers/dri-index.html?gsa_pos=1&wt.oss_r=1&wt.oss=programming%20cable%20driver
    but this didn't change something.
    If anybody has an solution for the problem, i would really appreciate it.
    Marc
    Hi
    Has anyone found a solution to this problem?
    I have encountered the same problem
    Anyone has VMware intsalled on the machine?
    Hello.
    Can you check, if the following services are running?
    parport.sys
    parvdm.sys
    To do so, just type the following in the command line:
    sc query parport
    sc queryc parvdm
    If both services are running, you can try the following:
    Goto .....\program files\Altera\80\quartus\drivers\i386
    and execute bblpt.exe with the option /i
    This should install the driver.
    Thats just the answer, I got from the support. In my case it did not solve the problem. If one of the services fail, you have a problem that is not related to Altera software, i think.
    Kind regards,
    Marc
    Hi There
    thank you for the repsonse
    I found one service not running
    C:\altera\72sp3\quartus\bin>sc query parvdm
    SERVICE_NAME: parvdm
    TYPE : 1 KERNEL_DRIVER
    STATE : 1 STOPPED
    (NOT_STOPPABLE,NOT_PAUSABLE,IGNORES_SHUTDOWN)
    WIN32_EXIT_CODE : 20 (0x14)
    SERVICE_EXIT_CODE : 0 (0x0)
    CHECKPOINT : 0x0
    WAIT_HINT : 0x0
    --- Quote Start ---
    --- Quote End ---
    I had problems installing ByteBlaster on my VMWare machine. Though I used Linux on my host as well as VMware machine, I was able to resolve the issue. I have reported my complete problem and solution here:
    http://www.alteraforum.com/forum/showthread.php?t=3052
    Good day readers
    I have managed to get my ByteBlaster working
    My LTP1 is native
    In Device manager it showed 2 x paralel ports
    LPT1 - ECP printer port
    LPT3 - Unusable Port
    I uninstalled LPT3
    i Then did update driver on LPT1 and chose ECP printer port
    in command line
    sc start parvdm.sys
    and bblpt.exe
    restart computer
    installed byteblster driver as per altera recommendation
    reboot
    and presto Bob's your Aunty
    Hello guys,
    I found thread with very good instructions, it helped me a lot :)
    this damn system cant allow me post link, because I am newbie. So, google term "Configuring ByteBlaster and putting Kernal Mode driver to bed"
    It is very good thread on alteraforum
