Kernel compilation failure for OpenCL FPGA.
I don't have 16.0.2 installed but I did a quick test with 16.1.2 on the same Nallatech board and it seems to work fine. I didn't wait until place and route finishes but the process indeed progressed further than it does for you. Since the error is happening after OpenCL to HDL conversion, this is likely not a problem related to your kernel. Maybe there are some files remaining from a previous compile that is interfering with the new one; have you tried fully removing the OpenCL project folder and retrying? This could also be some bug in some Quartus component that has been fixed in 16.1.0/16.1.2. I would strongly recommend using at least 16.1.2 on Arria 10 since 16.0.x performs terribly when it comes to packing math operations into the DSPs on Arria 10.
