keeping signals for signaltap
- 3 years ago
May be can try with attribute noprune check this https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/hdl/vhdl/vhdl_file_dir_noprune.htm, adding virtual pins in the Assignment Editor or use "pre-synthesis" filter in SignalTap's node selector and tapped the signal inside a "component" rather than in the top-entity where it is generated.
Sheng
If you want to preserve signals to tap as post-fit signals, you can use the "keep" and/or "preserve" synthesis attributes in your HDL code. There is a preserve for debug feature that uses project assignments, but that's only in the Pro edition of the tool. You can also just tap the signals pre-synthesis, basically tapping the signals directly from your RTL code.
