11 years ago
JTAG prgramming is not working in my Cyclone 4 based board.
Hi all,
I'm new to this forum. I have one issue in my Cyclone 4 (EP4CE6E22C8N) based development board..
Please provide some basic tips.
FYI: TDI, TMS pins of the JTAG connector always LOW (even I have pulled up by 10K resistor), I belive, it should not be LOW..
Please share your solution .
Thanks in advance..
ABCD
    hi all,
    FYI: the nSTASUS and CONFIG_DONE both are also in LOW state..
    Thanks and regards
    Assuming you have nothing connected to your JTAG header TMS and TDI should be high courtesy of the pull-ups you mentioned.
    CONF_DONE remains low until the FPGA is configured. The fact that nSTATUS is low implies that nCONFIG is being driven low - which it needs to be prior to programming in Passive Serial configuration. Otherwise it too should be pulled/driven high.
    Further info in configuration and remote system upgrades in cyclone iv devices (http://www.altera.com/literature/hb/cyclone-iv/cyiv-51008.pdf). Look at Figure 8-16 on page 8-36.
    If you need further help let us know which dev board you're using...
    Happy New Year,
    Alex
    --- Quote Start ---
    Happy New Year,
    Alex
    --- Quote End ---
    HI Alex,
    Thanks for your replay and information,
    "Assuming you have nothing connected to your JTAG header TMS and TDI should be high courtesy of the pull-ups you mentioned." - If JTAG header connected with USB blaster, the voltage level of TCK, TDI, TMS are 2.11V. (I'm using 3.3v IO supply).. I believe its loading with ground.
    "CONF_DONE remains low until the FPGA is configured. The fact that nSTATUS is low implies that nCONFIG is being driven low - which it needs to be prior to programming in Passive Serial configuration. Otherwise it too should be pulled/driven high." - in this circuit NnCONFIG already pulled high through 10K Resistor.
    If I tried to program is will be failed.
    if I tried to auto detect the device means "It thrown an error " Unable to scan device chain, Cant scan JTAG chain, do you want to open the JATG debugger to troubel shoot the JTAG chain?
    FYI: I didn't install any serial device in this board..
    Thanks and regards
