JTAG chain - unable to read device chain
Hello. I have a Quartus II issue related to FPGA detection. I have 2 different Cyclone V and 3 JTAG-Blaster (1 is USB and 2 is Ethernet). Quartus II detects blasters, but FPGA cannot. Whatever I do - "unable to read device chain". I don't know what to do - I've already reinstalled Quartus II and drivers, restarted JTAG-Server, tried different combinations of blasters and FPGAs - nothing can solve my problem. With that, I am sure that both FPGAs and blasters (at least ethernet) are working. I work on Windows 10, 64 bit.
- Ash_R_Altera
Please review the board connections as per the guidelines given in the Cyclone V Pin Connection Guildelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/cyclone-v/pcg-01014.pdf
There are some recommendations in the below Knowledge base:
Additional support:
Forum query:
Please let us know your findings.
Regards.
- Ash_R_Altera
Hi Nick,
Is there any update to your issue?
Please check following things on the board:
1) Whether all the power supplies reach upto their recommended levels before configuration starts.
2) Monitor nSTATUS pin. Expected to be low until the power supplies are stable.
3) If the power supplies are stable then are nSTATUS and nCONFIG pins going high. You should see these pins to remain in high state during configuration.
4) Is there any broken link in the daisy chain of the FPGA devices and the JTAG.
If possible please share a block diagram of how the devices are connected in chain and to the JTAG ports.
Regards.
