SZack
7 years agoJIC file format structure
I have a customer that wants to know how do they determine where the actual flash data begins after the header. Years ago they wrote code to use a processor to write .jic files into serial flash dev...
BKevi
4 years agoI know this is a very old thread but for the record.
You have to set the Non-Volatile Status Register on MT25Q manually with your ROM writer.
Address mode selection: Must be 4-Byte address mode
Reset/Hold disable : Must be Disabled
Dummy clock cycles : Must be 4
.rdp file needs to be bit swapped, if you was trying to flash it with a ROM writer.
If you were using .jic file and doing JTAG-Indirectly programming, it will configure Non-Volatile Status Register for you automatically.
MK_ABQ
Contributor
3 years agoIt's cool that you took your time and shared the information for the knowledge of the community. Kudos!
