14 years agojava exception when opening top level QSYS design
I am seeing this Java exception when I open my top level QSYS design. Any suggestions for workarounds are appreciated because now I have lost access to my design. Error: An unexpected ...
14 years agoSame issue in Qsys 12.0 Build 178
Info: Reading index /home/hill/altera/12.0/quartus/sopc_builder/bin/root_components.ipx Info: /home/hill/altera/12.0/quartus/sopc_builder/bin/root_components.ipx: Loading now from components.ipx Info: Reading index /home/hill/altera/12.0/quartus/sopc_builder/bin/ip_component_categories.ipx Info: /home/hill/altera/12.0/quartus/sopc_builder/bin/ip_component_categories.ipx described 0 plugins, 0 paths, in 0.03 seconds Info: /home/hill/altera/12.0/quartus/sopc_builder/bin/ip_component_categories.ipx matched 1 files in 0.03 seconds Info: Reading index /home/hill/altera/12.0/ip/altera/altera_components.ipx Info: /home/hill/altera/12.0/ip/altera/altera_components.ipx described 585 plugins, 0 paths, in 0.36 seconds Info: no _hw.tcl package requested, assuming package require -exact sopc 9.0 Info: no _hw.tcl package requested, assuming package require -exact sopc 9.0 Info: no _hw.tcl package requested, assuming package require -exact sopc 9.0 Info: no _hw.tcl package requested, assuming package require -exact sopc 9.0 Info: no _hw.tcl package requested, assuming package require -exact sopc 9.0 Info: no _hw.tcl package requested, assuming package require -exact sopc 9.0 Info: /home/hill/altera/12.0/ip/**/* matched 1201 files in 0.60 seconds Info: /home/hill/.altera.quartus/ip/12.0/**/* matched 0 files in 0.00 seconds Info: /home/hill/nios2-rtems/hdwDesign/timedDataSys/ip/**/* matched 0 files in 0.00 seconds Info: /home/hill/nios2-rtems/hdwDesign/timedDataSys/* matched 57 files in 0.03 seconds Info: /home/hill/nios2-rtems/hdwDesign/timedDataSys/*/* matched 1364 files in 0.21 seconds Info: Reading index /home/hill/altera/12.0/quartus/sopc_builder/builtin.ipx Info: /home/hill/altera/12.0/quartus/sopc_builder/builtin.ipx described 95 plugins, 0 paths, in 0.07 seconds Info: /home/hill/altera/12.0/quartus/sopc_builder/**/* matched 10 files in 0.07 seconds Info: Reading index /home/hill/altera/12.0/quartus/common/librarian/factories/index.ipx Info: /home/hill/altera/12.0/quartus/common/librarian/factories/index.ipx described 150 plugins, 0 paths, in 0.10 seconds Info: /home/hill/altera/12.0/quartus/common/librarian/factories/**/* matched 4 files in 0.10 seconds Info: /home/hill/altera/12.0/quartus/sopc_builder/bin/$IP_IPX_PATH matched 1 files in 0.00 seconds Info: /home/hill/altera/12.0/quartus/sopc_builder/bin/root_components.ipx described 0 plugins, 9 paths, in 1.05 seconds Info: /home/hill/altera/12.0/quartus/sopc_builder/bin/root_components.ipx matched 1 files in 1.05 seconds Info: Loading presets Warning: ddr_sdram: Used altmemddr 12.0 (instead of 11.1) Warning: tse_mac: Used triple_speed_ethernet 12.0 (instead of 11.1) Warning: sgdma_tx: Used altera_avalon_sgdma 12.0 (instead of 11.1) Warning: clk: Used clock_source 12.0 (instead of 11.1) Warning: dma_csr_bridge: Used altera_avalon_mm_bridge 12.0 (instead of 11.1) Warning: sys_clk_timer: Used altera_avalon_timer 12.0 (instead of 11.1) Warning: periph_clk: Used clock_source 12.0 (instead of 11.1) Warning: mm_bridge: Used altera_avalon_mm_bridge 12.0 (instead of 11.1) Warning: sysid: Used altera_avalon_sysid_qsys 12.0 (instead of 11.1) Warning: jtag_uart_console: Used altera_avalon_jtag_uart 12.0 (instead of 11.1) Warning: periph_clk: Used clock_source 12.0 (instead of 11.1) Warning: pipeline_bridge: Used altera_avalon_mm_bridge 12.0 (instead of 11.1) Warning: tight_coupled_code_ram: Used altera_avalon_onchip_memory2 12.0 (instead of 11.1) Info: no _hw.tcl package requested, assuming package require -exact sopc 9.0 Warning: nios2: Used altera_nios2_qsys 12.0 (instead of 11.1) Warning: tsc_flash: Used altera_generic_tristate_controller 12.0 (instead of 11.1) Warning: tristate_pin_sharer: Used altera_tristate_conduit_pin_sharer 12.0 (instead of 11.1) Warning: tristate_bridge: Used altera_tristate_conduit_bridge 12.0 (instead of 11.1) Warning: altpll: Used altpll 12.0 (instead of 11.1) Warning: periph_bridge: Used altera_avalon_mm_clock_crossing_bridge 12.0 (instead of 11.1) Warning: cpu_bridge: Used altera_avalon_mm_bridge 12.0 (instead of 11.1) Warning: ddr_ref_clk: Used clock_source 12.0 (instead of 11.1) Error: An unexpected error occurred during Open System: java.lang.NullPointerException Debug: java.lang.NullPointerException at com.altera.sopcmodel.avalon.AvalonValidator.validateTightlyCoupledPoints(AvalonValidator.java:422) at com.altera.sopcmodel.avalon.AvalonValidator.validate(AvalonValidator.java:62) at com.altera.sopcmodel.ensemble.EnsembleValidator.connectionClassValidations(EnsembleValidator.java:893) at com.altera.sopcmodel.ensemble.EnsembleValidator.validate(EnsembleValidator.java:120) at com.altera.sopcmodel.ensemble.Ensemble.validateSelf(Ensemble.java:1284) at com.altera.sopcmodel.beanelement.BeanElement.validateSelf(BeanElement.java:392) at com.altera.sopcmodel.beanelement.BeanElement.validate(BeanElement.java:363) at com.altera.sopcdocument.ReadDocument.read(ReadDocument.java:235) at com.altera.sopcfactories.QsysFactory$1.getObject(QsysFactory.java:119) at com.altera.sopcmodel.util.CatalogCard.getObject(CatalogCard.java:481) at com.altera.sopcmodel.util.CatalogCard$1.getObject(CatalogCard.java:131) at com.altera.sopcmodel.util.CatalogCard.getObject(CatalogCard.java:481) at com.altera.sopcmodel.util.CatalogCard$1.getObject(CatalogCard.java:131) at com.altera.sopcmodel.util.CatalogCard.getObject(CatalogCard.java:481) at com.altera.sopcplatform.librarian.LibrarianUtils.readEnsemble(LibrarianUtils.java:449) at com.altera.sopceditor.util.EnsembleIO.loadEnsemble(EnsembleIO.java:163) at com.altera.sopceditor.tools.saveandload.LoadEnsembleTask.run(LoadEnsembleTask.java:198) at com.altera.ui.app.base.EditorTaskRunner$12.run(EditorTaskRunner.java:461) at com.altera.ui.app.base.ThreadRunner$1.run(ThreadRunner.java:65) at java.lang.Thread.run(Unknown Source)
