13 years agoHello,
I got the work around for the installations and I had been able to install the following in my machine: Quartus II 12.1 Web edition (32 & 64 bit). Modelsim Altera 10.1 b (quartus II 12.1) starter edition. NIOS II IDE version 12.0. I wanted to start with a custom instruction example in the NIOS II IDE, I had been looking at the PDF https://www.lri.fr/~de/ug_nios2_custom_instruction.pdf Page 30 has a design example for a leading zeros detector. To implement that, Creating a New Nios II IDE Project is the first step. In that, I am stuck at step 3, i.e 'From Select Project Template, select Custom Instruction Tutorial.' In my NIOS II IDE (eclipse), I am not able to see such a template. I hope I miss some install directories for NIOS II. How will I find the NIOS II Custom Instruction Tutorial directory and copy it to the NIOS install directory? Some one please advice me, it will be a huge help. Thank You, Akhil
