8 years agoIssue installing USB-Blaster II to Quartus Prime...
Hi guys. So I have Quartus Prime Lite installed, but I think I missed one thing. I am not able to connect my Max10 Neek development board to communicate via on-board USB-Blaster II. When I first c...
8 years agoThanks, Anard. I have not been able to get the PC to install the correct drivers yet, so the Device manager shows a generic driver of some sort that Windows10 picked.
So it shows up as a USB device 'VID_XXX' composite' - it's the last entry 'USB Serial Converter' in the attached image. It keeps coming back when I remove it or remove/re-install Quartus. When I in-installed the driver in this window, Win10 did not allow me to find drivers after connecting the board with Blaster ii (Terasic Max2 NEEK) - it simply re-installed the drivers it chose for me the first time. So I re-installed Quartus. Still, I am unable to raise the 'new hardware found' as expected after a re-install - there must be remnents I need to remove..? The driver is showing that it is 'not migrated' and in the other panel it is 'working properly' - the device show in the detains in the attached image. Is this a situation where I have to go into safe mode (or something) to remove a deeper driver remnant? Thanks for your support. Cheers, Bob Windows10 64bit Pro i7 QC
