Is wire level connectivity supported in Quartus Standard Edition?
I would like to use the wire level connectivity in the Platform Designer but I run in the following error:
Error: invalid command name "set_wirelevel_expression"
The feature shows up in the documentation of the Standard Edition.
However it does not seems to be supported in GUI or scripts. It requires extra license or it is a documentation issue?
Laszlo
Info: *******************************************************************
Info: Running Quartus Prime Shell
Info: Version 18.1.0 Build 625 09/12/2018 SJ Standard Edition
1 Reply
- GuaBin_N_Intel
Contributor
The wire-level expression should be available in Quartus Pro not in Standard edition. When you open Platform Designer in Pro, Wire-Level expression editor option can be seen in View. It must be some mistake in the documentation.
