LNagy2
7 years agoIs wire level connectivity supported in Quartus Standard Edition?
I would like to use the wire level connectivity in the Platform Designer but I run in the following error: Error: invalid command name "set_wirelevel_expression" The feature shows up in the docume...
GuaBin_N_Intel
Contributor
7 years agoThe wire-level expression should be available in Quartus Pro not in Standard edition. When you open Platform Designer in Pro, Wire-Level expression editor option can be seen in View. It must be some mistake in the documentation.
