Altera_ForumHonored Contributor15 years agoIs underscore unallowed??? ("0000_0100") Hi all, I allways get a compiler error if I try to separate long binary values with underscore! example: signal shifreg :: std_logic_vector(15 downto 0); shiftreg <= "0000_0000_0000_00...Show More
Altera_ForumHonored Contributor15 years agoChange "0000_0000_0000_00" to B"0000_0000_0000_00". Good luck, Ton
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
