MLO3
7 years agoIs there's a way to convert program used in cyclone II to Cyclone V?
Hello everyone, I worked in a program in quartus II 4 years by using cyclone II* and now a day i just wanted to re-use the same program with cyclone V* but i'm getting error message of pins that 's ...
Nooraini_Y_Intel
7 years agoHi MLO3,
Which configuration scheme that you are trying to use with the Cyclone V device? If you are able to migrate the Cyclone II design into the newer Quartus version and recompile for Cyclone V device, then there should be a .sof file generated for Cyclone V device. When you say trying to load the file trough the software, it says "FAILED", I assume this is referring to Quartus programmer error. Can you provide more detail screen shots on the error message log from Quartus when the .sof file programming failed?
Nooraini
