PixelPusher
4 months agoIs there any way to script the creation of a signal tap instance?
I have been trying to see if it is possible to create a signal tap instance using a scripted approach. For example, create an instance, add some signals from the design using wildcards, setup trigger...
sstrell
4 months agoThe latter: put Signal Tap in a reusable design block and make multiple design blocks that you can basically just swap in and out.
As mentioned, you can't set up the .stp file without using the GUI.
