PixelPusher
4 months agoIs there any way to script the creation of a signal tap instance?
I have been trying to see if it is possible to create a signal tap instance using a scripted approach. For example, create an instance, add some signals from the design using wildcards, setup trigger...
sstrell
4 months agoYou may want to look at a block-based design approach, creating reusable design partitions that include Signal Tap instances. There's a user guide all about doing this in Pro:
https://docs.altera.com/r/docs/683247/current
