16 years agoThere wasn't any error, the onchip-memory(rom) was not getting initialized.
I solved the problem now.I had set that particular module which has the onchip-memory(rom) as DESIGN PARTITION then.so it was not compiling the newly added changes. Now it is working obsolutely fine after i deselected the SET AS DESIGN PARTITION option for that module and the nios is executing from the onchip -ROM
