Is there a way to change ModelSim's default radix in code or command line?
- 5 years ago
Thank you ShyanYewT,
Unfortunately, the default does not carry when I move source files to a new folder and start a new Modelsim. I would have liked to have found a way to set it in my source testbench or .do file which contains the:
vsim -t 1ps -L altera_ver -L lpm_ver .....
However, going to the vsim in the command reference manual, I found:
vsim -default_radix unsigned -t 1ps -L altera_ver -L lpm_ver .....
for the vsim command. This is what I was looking for and I wonder why my .pdf viewer never did show this text of 'default_radix' when I did a search for 'radix'. For some reason, maybe the underscore, the - in front, or that it was a blue link, all the text search showed was a number of other 'radix' references throughout the documentation.
With the Modelsim GUI opened, you might change the radix following the steps below:
1. Select Simulate > Runtime options...
2. In Default Radix box, select your desired radix.
Hope it helps.
- BrianHG5 years ago
- RichardT_altera5 years ago
I’m glad that you found the answer for your question, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
