Is there a way to avoid clicking "Start Compilation" multiple times?
- 7 years ago
Please check multiple options available under 'Processing' -> 'Start' menu.
"Is there a way to clean out build files?" -- - - - - ether you can do 'Project' -> 'Clean Project' or best way is, close the Quartus tool & delete the 'db' & 'Incremental_db' from project generation directory & then try to compile.
Please let me know, if you have any different concern, also provide error message screenshot.
Vicky
Please check the below solution,
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd09162005_332.html
let me know, how it works for you.
Vicky
- OHarb7 years ago
This fixes the Project->Clean error, but I still see the Start Compile error:
[deleted]
Error(16045): Instance "aptos|configurationWordCache|tags_address_rtl_0|auto_generated" instantiates undefined entity "altsyncram_elk1"
Error(16185): Can't elaborate user hierarchy "..|tags_address_rtl_0|auto_generated"
Error(16185): Can't elaborate user hierarchy "..|tags_address_rtl_0"
[deleted]
