Is there a way to avoid clicking "Start Compilation" multiple times?
- 7 years ago
Please check multiple options available under 'Processing' -> 'Start' menu.
"Is there a way to clean out build files?" -- - - - - ether you can do 'Project' -> 'Clean Project' or best way is, close the Quartus tool & delete the 'db' & 'Incremental_db' from project generation directory & then try to compile.
Please let me know, if you have any different concern, also provide error message screenshot.
Vicky
Vicky
- OHarb7 years ago
Here are the errors. There are lots of them and they are all very similar.
[deleted]
Error(16045): Instance "aptos|configurationWordCache|tags_address_rtl_0|auto_generated" instantiates undefined entity "altsyncram_elk1"
Error(16185): Can't elaborate user hierarchy "..|tags_address_rtl_0|auto_generated"
Error(16185): Can't elaborate user hierarchy "..|tags_address_rtl_0"
[deleted]
Project -> Clean, resulted in:
Error(23035): Tcl error: ERROR: Can't access revision 'myrevisionname'. The revision may not exist, or there may be an error in the revision settings.
while executing
"project_clean -revision $revision"
invoked from within
"if { ![project_exists $project_name] } {
post_message -type error "Cannot clean project $project_name: this project doesn't exist"
} else {
pr..."
(file "/opt/intelFPGA_pro/19.2/quartus/common/tcl/internal/qsh_clean.tcl" line 81)
Error(23031): Evaluation of Tcl script /opt/intelFPGA_pro/19.2/quartus/common/tcl/internal/qsh_clean.tcl unsuccessful
After cleaning, even though it failed, Quartus started compilation(got past synthesis) fine.
