ARach7
7 years agoIs there a plan to fix VHDL code of Cyclonev_atom? it contain plenty of errors.
Cyclonev VHDL flavor gives elaboration error with VCS. They are justified. Is there an ETA for a fix ? %sed -n '6482,6599p;6599q' /global/snps_apps/quartus_18.0.0.614/quartus/eda/sim_lib/cyclon...
KhaiChein_Y_Intel
7 years agoHi,
I actually tried to compile all the simulation library files without stripping it. The error mentioned did not occur. I was thinking if we miss out some of the important files that cause this error. This is the reason why I suggest to compile/simulate using the proper flow above and see if the same error occurs. Then we can check one by one to figure out what is the root cause of this.
Thanks for understanding.
