Is there a plan to fix VHDL code of Cyclonev_atom? it contain plenty of errors.
I cannot reproduce the error. Running vcs tb_cyclonev_termination gives error below:
*** Using c compiler gcc instead of cc ...
Chronologic VCS (TM)
Version N-2017.12-SP2-4_Full64 -- Wed Jul 10 16:17:58 2019
Copyright (c) 1991-2017 by Synopsys Inc.
ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Top Level Modules:
Warning-[ELW_UNBOUND] Unbound component
The component instantiation
'/\/tb_cyclonev_termination/cyclonev_termination\/INST' (file:
/folder/stam.vhd, line: 82) will
have no effect because component 'CYCLONEV_TERMINATION_ENCRYPTED' is
unbound. No entity definition for component 'CYCLONEV_TERMINATION_ENCRYPTED'
can be found in the following libraries ( WORK ) referenced by the
architecture 'BEHAVIOR' of entity 'CYCLONEV_TERMINATION'.
Please bind the component explicitly to an entity (architecture) pair, and
verify that the pair was analyzed successfully.
TimeScale is 1 s / 1 ns
Warning-[TFIPC] Too few instance port connections
t.v, 3
"cyclonev_termination cyclonev_termination();"
The above instance has fewer port connections than the module definition.
Please use '+lint=TFIPC-L' to print out detailed information of unconnected
ports.
Note-[SIMU-RESOLUTION] Simulation time resolution
Simulation time resolution is 1 NS
Starting vcs inline pass...
2 modules and 0 UDP read.
However, due to incremental compilation, no re-compilation is necessary.
make: Warning: File `vh/sc_filelist' has modification time 9.5 s in the future
make[1]: Warning: File `vh/sc_filelist' has modification time 9.5 s in the future
rm -f _csrc*.so pre_vcsobj_*.so share_vcsobj_*.so
make[1]: warning: Clock skew detected. Your build may be incomplete.
ld -shared -o .//../simv.daidir//_csrc0.so objs/amcQw_d.o
rm -f _csrc0.so
if [ -x ../simv ]; then chmod -x ../simv; fi
g++ -o ../simv -Wl,-rpath-link=./ -Wl,-rpath='$ORIGIN'/simv.daidir/ -Wl,-rpath=./simv.daidir/ -Wl,-rpath='$ORIGIN'/simv.daidir//scsim.db.dir -rdynamic -Wl,-E -Wl,-rpath=/tools/vcsmx/N-2017.12-SP2-4/linux64/linux64/lib -L/tools/vcsmx/N-2017.12-SP2-4/linux64/linux64/lib _1668_archive_1.so _prev_archive_1.so _csrc0.so SIM_l.o _csrc0.so rmapats_mop.o rmapats.o rmar.o rmar_nd.o rmar_llvm_0_1.o rmar_llvm_0_0.o linux64_scvhdl_0.so vh/scscomm.o vh/scsFilelist.o -lzerosoft_rt_stubs -lerrorinf -lsnpsmalloc -lvfs -lvirsim -lvcsnew /tools/vcsmx/N-2017.12-SP2-4/linux64/linux64/lib/vcs_main.o -lvcsmx -lreader_common /tools/vcsmx/N-2017.12-SP2-4/linux64/linux64/lib/libBA.a -lsimprofile -luclinative /tools/vcsmx/N-2017.12-SP2-4/linux64/linux64/lib/vcs_tls.o -Wl,-whole-archive -Wl,-no-whole-archive /tools/vcsmx/N-2017.12-SP2-4/linux64/linux64/lib/vcs_save_restore_new.o -ldl -lc -lm -lpthread -ldl
../simv up to date
make: warning: Clock skew detected. Your build may be incomplete.
CPU time: .385 seconds to compile + .014 seconds to elab + .231 seconds to link
YY
