Is there a plan to fix VHDL code of Cyclonev_atom? it contain plenty of errors.
Sure.
- Strip the definitions of entity cyclonev_termination and of entity cyclonev_termination_logic from the full file:
(Please change path of $Quartus_ROOTDIR , to match your installation of quartus_18.0.0.614)
%sed -n '6482,6599p;6599q' /global/snps_apps/quartus_18.0.0.614/quartus/eda/sim_lib/cyclonev_atoms.vhd > stam.vhd
%sed -n '6421,6481p;6481q' /global/snps_apps/quartus_18.0.0.614/quartus/eda/sim_lib/cyclonev_atoms.vhd > stam2.vhd
2.Create this t.v Verilog file
module tb_cyclonev_termination();
cyclonev_termination cyclonev_termination ();
endmodule
module tb_cyclonev_termination_logic();
cyclonev_termination_logic cyclonev_termination_logic ();
endmodule
3.Run these VCS commands:
%vlogan t.v
%vhdlan stam.vhd sta2.vhd
%vcs tb_cyclonev_termination
You will get 4 errors of Error-[BADFORMALSPEC] Bad formal part specified, one error of Error-[ANALERR_SIZEMISMATCH1] Size mismatch, one error of Error-[ANL-PORTDI-ERR] Port direction mismatch
Now run this command
%vcs tb_cyclonev_termination_logic
You will get two errors of type Error-[BADFORMALSPEC] Bad formal part specified
