Is the license perpetual-the fixed subscription license of Intel® Quartus® Prime Pro Edition software
We are planning to buy the fixed subscription license of Intel® Quartus® Prime Pro Edition software.
We find online (https://www.intel.com/content/www/us/en/programmable/buy/design-software.html) it says:
Intel® Quartus® Prime Pro Edition software fixed-node subscription supports all devices on Windows platforms. Includes access to Intel Quartus Prime Standard Edition and software updates for one year.
$3,995 USD, Ordering code - SW-PE-QRTS-FIX.
Could you please tell me:
1, does it mean it can be updates to new released version within one year, and it can be used without time limit? In an other words, is it a perpetual license, or will it expire after one year?
2, does it only support Windows platform? If I install it on a Windows PC, and for some reason I change the OS of that PC into linux (hardware not changed), could I use the same license to run Quartus Prime for linux on that linux PC?
Seigen Nakasone (Qingyuan Tian)
1 Reply
- Vicky1
"1, does it mean it can be updates to new released version within one year, and it can be used without time limit? In an other words, is it a perpetual license, or will it expire after one year?" - - - - - - It will expire after 12 months & user need to renew it, on active maintenance or less than 30 days after expiration.
Refer the Step 6: Specify the Intel FPGA Software License from below Intel FPGA Software Installation and Licensing Quick Start,
https://www.intel.com/content/www/us/en/programmable/documentation/esc1425943996095.html#mwh1410890911982
Please refer the table & Note 3. for renewal policy,
"2, does it only support Windows platform? If I install it on a Windows PC, and for some reason I change the OS of that PC into linux (hardware not changed), could I use the same license to run Quartus Prime for linux on that linux PC?" - - - - - - Yes, you can use it but first ensure the supported operating system from table below,
https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html
For Licensing most important thing is network interface card (NIC) ID is a 12‑digit hexadecimal string embedded in the network card that uniquely identifies a computer, check the 'Identifying Host's NIC ID" from link below,
Vicky
