anilinintel
8 years agoIs my IP integration of modular-sgdma (with prefetcher enabled )is correct ?
i enabled prefetcher core option enabled. where should i connect this additional ports descriptor read master and write master. ? and anyone help me with the concept how and where descriptors should...
anilinintel
7 years agoThanks for ths answer. The picture shown is somepart only. There was a clock source and reset source. We use 4 memories i.e onchip memories. One for holding elf file i.e code memory and other for storing descriptors. Other as source buffer, and other as destination buffer. We fill data in source buffer from nios via small "for loop". Now the question is , want a C code to examine this msgdma performance while moving data into destination buffer i.e onchip mem 4.
Reviewed pdf files, HAL api drivers , internet search ..etc, even webcase not solved this issue till now.
