anilinintel
8 years agoIs my IP integration of modular-sgdma (with prefetcher enabled )is correct ?
i enabled prefetcher core option enabled. where should i connect this additional ports descriptor read master and write master. ? and anyone help me with the concept how and where descriptors should...
Ahmed_H_Intel1
7 years agoI see some mistakes :
1- where is the clock source
2-Connect the NIOS II Instruction master to the memory that will hold the code only, the rest should be connected to the data master.
3- Where is the descriptor memory? I cannot see it.
4-What errors the Qsys shows?
