14 years agohi again kaz, thanx for your previous reply...i tried to pipeline the bottleneck using the following code, but it doesn't give me the correct results even after i perform pipeline balancing:
Library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity TEA_en is
port(
clock: in std_logic; --clock input
input_data: in std_logic_vector (63 downto 0); --input data
key : in std_logic_vector (127 downto 0); --secret key 127 downto 0--
encrypted_data: out std_logic_vector (63 downto 0) --output/encrypted data
end entity TEA_en;
architecture behave of TEA_en is
--declare signals
signal Key0, Key1, Key2, Key3 : std_logic_vector (31 downto 0);
signal Z, Y : std_logic_vector (31 downto 0);
signal count :integer range 0 to 32:=0; --constrained counter (counts from 0 to 32) improves throughput by 1 ns!
signal pipeline_0,pipeline_1,pipeline_2,pipeline_3,pipeline_4,pipeline_5,pipeline_6,pipeline_7:std_logic_vector(31 downto 0);
begin
--separate key into four parts
Key0<=key(127 downto 96);
Key1<=key(95 downto 64);
Key2<=key(63 downto 32);
Key3<=key(31 downto 0);
Process(Input_data, clock)
--declare and initialize variable
Variable delta: std_logic_vector (31 downto 0):=x"9e3779b9";
Variable sum: std_logic_vector (31 downto 0):=x"00000000";
Variable Zeq,Yeq,Z,Y: std_logic_vector (31 downto 0);
Begin
If(rising_edge(clock)) then
If (count<1) then --separate input data into two parts
Z:=input_data(63 downto 32); --part 1 (32bits)
Y:=input_data(31 downto 0); --part 2 (32bits)
Else --null;
End if;
If (count<32) then
--Encryption routine algorithms
sum:=sum+delta;
for i in 1 to 8 loop
case i is
when 1=> pipeline_0 <=( (Z(27 downto 0) & "0000")+Key0);
when 2=> pipeline_1 <=(Z+ sum) ;
when 3=> pipeline_2 <=(("00000" & Z(31 downto 5))+Key1);
when 4=> pipeline_3 <=( (Y(27 downto 0) & "0000")+Key2) ;
when 5=> pipeline_4 <=(Y+ sum) ;
when 6=> pipeline_5 <=(("00000" & Y(31 downto 5))+Key3) ;
when 7=> pipeline_6 <=pipeline_0 xor pipeline_1 xor pipeline_2;
when 8=> pipeline_7 <=pipeline_3 xor pipeline_4 xor pipeline_5;
when others=> null;
end case;
end loop;
Y:=Y+pipeline_6;
Z:=Z+pipeline_7;
--Output encrypted data
Encrypted_data<=Y&Z;
else null;
end if;
count<=count+1; --increase value of count
End if;
End process;
end architecture behave;
anything i did wrong in the process? many thanx again for the help!^^
