CAlex
Contributor
3 years agoIRQ sender for my personal IP
I wrote a personal IP which will send IRQ to HPS(Liunx) in some situation.
I'm planning to write the LKM to use that IRQ.
But parameter setting confused me a lot.
Could you guys ...
CAlex
Contributor
3 years agoHi,
In that case, it says it's the name of linked Avalon-mm port name.
And if I put the irq signal to the f2h_irq directly, do I need to set the Avalon MM name,clock and reset signals?
If it must, is that the Avalon MM pipeline bridge my_timer connected to?
