13 years ago
IP lpm_ff has been removed?
I use QuartusII 11.1sp2, I just find IP core lpm_ff has been removed, is that same in your Quartus?
    Does anybody who used lpm_ff find this? Allthough lpm_ff is a very basic IP, but it provides some functions which "<=" in verilog does not have such as syn/asyn reset. So it seems bring some inconveniences.
    I think, Altera has cleaned up the Megawizard from functions, that can be easily replaced by a few lines of HDL code. lpm_ff nevertheless exists in the lpm libraries for backward compatibility and can be instantiated in your code if you copy the component/module definitions from previous Quartus versions or write new interface instances from the scratch.
    If you want to implement sync and async reset this is easily done in Verilog:
    module dFF(
       input clk,
       input asyncReset,
       input syncReset,
       input d,
       output q
       reg r;
       assign q = r;
       always @(posedge clk, posedge asyncReset) begin
          if(asyncReset)
             r <= 1'b0;
          else if(syncReset)
             r <= 1'b0;
          else
             r <= d;
       end
    endmodule
    Thanks FvM. The only thing is when I write a verilog code to describe the behavior of a simple module, I don't know whether it is optimized same as the IP core in Megawizard.
    For example, originally I always use IP "Counter" to count the number. Actually, in some cases describe the counter using behavior description Verilog will be much simpler. And I write two codes one with IP counter another just using Verilog behavior description, then I found the cost number of LEs are very similar (should be same but I am not sure), and timing parameters are similar too, then I will prefer using Verilog to write instead of using IP counter.
    The similar things will happen in other simple IP like add, subtract.
    I just wonder when you confront the similar problems, how do you which one is better? Using IP or write behavior description code by yourself?
    Thanks very much.
    Yes, you are right. The only thing I am worried is whether Altera IP is more optimized.
    Now, the lpm_ff has been removed. So the code you post will be the first choice.
    Thanks very much.
