11 years ago"ip-generate FAILED" after upgrading AOC
I recently attempted to upgrade my Altera OpenCL SDK to version 14.1. Everything seemed to complete successfully so then I attempted to compile a test program. When I attempted to compile a program with this new version, I received the following message.
C:\Users\Me\workspace > aoc --board p385_mac_a7 -v hello_world.cl
aoc: Environment checks are completed successfully.
You are now compiling the full flow!!
aoc: Selected target board p385_mac_a7
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Compiling....
aoc: Linking with IP library ...
aoc: First stage compilation completed successfully.
Error: ip-generate FAILED.
Refer to hello_world/hello_world.log for details.
Here is what the log file had about the error: --- Quote Start --- ... 2014.12.18.13:55:53 Info: set_validation_property AUTOMATIC_VALIDATION false 2014.12.18.13:55:53 Info: add_instance kernel_system kernel_system 2014.12.18.13:56:01 Info: add_connection board.kernel_clk kernel_system.clock_reset 2014.12.18.13:56:01 Info: add_connection board.kernel_clk2x kernel_system.clock_reset2x 2014.12.18.13:56:01 Info: add_connection board.kernel_reset kernel_system.clock_reset_reset 2014.12.18.13:56:01 Info: add_connection kernel_system.kernel_mem0 board.kernel_mem0 2014.12.18.13:56:01 Info: add_connection kernel_system.kernel_mem1 board.kernel_mem1 2014.12.18.13:56:01 Info: add_connection board.kernel_irq kernel_system.kernel_irq 2014.12.18.13:56:01 Info: add_connection board.kernel_cra kernel_system.kernel_cra 2014.12.18.13:56:01 Info: add_connection board.acl_internal_snoop kernel_system.cc_snoop 2014.12.18.13:56:01 Info: add_connection board.kernel_clk kernel_system.cc_snoop_clk 2014.12.18.13:56:01 Info: save_system 'ip-generate' is not recognized as an internal or external command, operable program or batch file. --- Quote End --- Has anyone seen anything like this or know what could be the cause of it?
