9 years agoIP_Compiler for PCI Express - timing constraints
Hi folks,
I'd like to check with you if the warnings I get are normal and if I should do anything else. In QSys, I use the IP_Compiler for PCI Express configured for a hard IP of a Cyclone IV GX. It generates a file called altera_pci_express.sdc, which is added to the Quartus project. Here is its content:
create_clock -period "100 MHz" -name {refclk_pci_express} {*refclk_export}# SERDES Digital Reset inputs are asynchronous
set_false_path -to {*tx_digitalreset_reg0c}
set_false_path -to {*rx_digitalreset_reg0c}
set_clock_groups -exclusive -group -group
set_multicycle_path -end -setup -from 2;
set_multicycle_path -end -hold -from 1;
set_multicycle_path -end -setup -from ] 3;
set_multicycle_path -end -hold -from ] 2;
Now, when I read that sdc file, I get these warnings:
Ignored filter at altera_pci_express.sdc(14): *refclk_export could not be matched with a port or pin or register or keeper or net or combinational node or node
Ignored create_clock at altera_pci_express.sdc(14): Argument <targets> is not an object ID
Ignored filter at altera_pci_express.sdc(16): *tx_digitalreset_reg0c could not be matched with a clock or keeper or register or port or pin or cell or partition
Ignored set_false_path at altera_pci_express.sdc(16): Argument <to> is not an object ID
Ignored filter at altera_pci_express.sdc(17): *rx_digitalreset_reg0c could not be matched with a clock or keeper or register or port or pin or cell or partition
Ignored set_false_path at altera_pci_express.sdc(17): Argument <to> is not an object ID
Ignored filter at altera_pci_express.sdc(18): *central_clk_div0* could not be matched with a clock
Ignored filter at altera_pci_express.sdc(18): *_hssi_pcie_hip* could not be matched with a clock
Ignored set_clock_groups at altera_pci_express.sdc(18): Argument -group with value contains zero elements
Are these normal? I am not sure of the workflow usually used with such an IP, should I modify that sdc file by hand after generation to fix these issues? I found this (https://www.altera.com/support/support-resources/knowledge-base/solutions/rd05072014_784.html) in the knowledge base which I guess means usually we don't change the file. I did change the PCI Express refclk name to match the one in my top design, but remains the other warnings which I am not sure what to do with. Thanks for the help, SmithNo RepliesBe the first to reply
