9 years agoIOPLL does not reach core routing & was not previously routed by FPP
Hi ,
Quartus Prime version: 16.0.2 Part : 10AX115N3F45I2SG There are just two output ports within mpll_fpga. When doing fitter, I got below error. From chip planner, one bufg promoted for mpll_fpga|outclk[0], but wo for mpll_fpga|outclk[1]. All 13 promoted bufg used list below,Pls help check! Thx a lot! Info (11178): Promoted 7 clocks (6 global, 1 periphery) Info (13173): mpll_fpga_altera_iopll_160_xh2fzhi:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|outclk[0]~CLKENA0 (6 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3G_G_I21 Info (13173): syspll_fpga_altera_iopll_160_quwxgsi:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|outclk[0]~CLKENA0 (61 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3H_G_I22 Info (13173): syspll_fpga_altera_iopll_160_quwxgsi:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|outclk[1]~CLKENA0 (6 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3H_G_I20 Info (13173): sys_24mhz_altera_iopll_160_mv6tpja:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|outclk[0]~CLKENA0 (174 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_2A_G_I7 Info (13173): syspll_u0|syspll_fpga_altera_iopll_160_quwxgsi:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|fbclk_out~CLKENA0 (1 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3H_G_I16 Info (13173): mpll_fpga_uu|mpll_fpga_altera_iopll_160_xh2fzhi:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|fbclk_out~CLKENA0 (1 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3G_G_I23 Info (13173): lvds_four_line_a10_u|altera_lvds_160_5jmn5my:lvds_0|altera_lvds_core20_160_e33lwcy:core|altera_lvds_core20:arch_inst|altera_lvds_core20_pll:internal_pll.pll_inst|outclock[2]~CLKENA0 (2138 fanout) drives Periphery Clock Region 14, with the buffer placed at CLKCTRL_3B_P14_I5 Info (11191): Automatically promoted 6 clocks (6 global) Info (13173): a_cclk~CLKENA0 (4788 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3D_G_I17 Info (13173): a_cclk~CLKENA0 (19005 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3D_G_I19 Info (13173): a_cclk~CLKENA0 (26297 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3D_G_I18 Info (13173): rst_sync_2d~CLKENA0 (3314 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3E_G_I26 Info (13173): rst_sync_2d~CLKENA0 (4570 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3E_G_I27 Info (13173): reg_rst_o~0CLKENA0 (3102 fanout) drives Global Clock Region, with the buffer placed at CLKCTRL_3E_G_I25 ----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Info (170189): Fitter placement preparation operations beginning Info (14951): The Fitter is using Advanced Physical Optimization. Info (170190): Fitter placement preparation operations ending: elapsed time is 00:06:02 Info (170191): Fitter placement operations beginning Info (170137): Fitter placement was successful Info (170192): Fitter placement operations ending: elapsed time is 00:05:48 Info (11888): Total time spent on timing analysis during Placement is 115.40 seconds. Info (170193): Fitter routing operations beginning Error (14971): Top level port of IO_48_LVDS_TILE_RE:X142Y168Z0I3623 for oterm mpll_fpga_altera_iopll_160_xh2fzhi:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|outclk[1] does not reach core routing & was not previously routed by FPP. Info (11888): Total time spent on timing analysis during Routing is 0.00 seconds. Info (16607): Fitter routing operations ending: elapsed time is 00:00:02 Error: An error occurred during routing BR TonyNo RepliesBe the first to reply
