15 years agoThe behaviour is due to FPGA hardware (weak pull-up resistors) and not depending on Quartus. If you think about it, you'll realize, that the configuaration can't have an effect on the device behaviour before it's loaded. You can either change the polarity of your logic signal, or place a pull-down resistor of 1k to override the weak pull-up.
