10 years agoInterpretation of numberic constants as signed/unsigned
Hi All, I'm new to this forum, and very new to FPGAs. I've got myself a simple Cyclone II dev board and a copy of Quartus, and I'm attempting to learn some VHDL. I've just got to the stage of blin...
10 years agoHi Tricky,
That's really helpful, thanks. I'd understood that the width of the "built-in" integer was architecture dependent, it just hadn't clicked that it was always a signed type. Now I think of it, of course that's completely equivalent to C (which I'm more familiar with) where int a ; is a signed type (of architecture-dependent width) and unsigned int a ; is the unsigned of the same width. My textbook ("The students' guide to...") hasn't mentioned the "unsigned" type yet - the only integer type that's listed is called "integer". As I said, I'm very new to all this. I notice that your definition syntax is different to that used in the book, too. The form unsigned(3 downto 0) looks like a type conversion - it it related? Regarding my two example definitions: type uint32 is range 0 to 10 ; subtype uint32 is integer range 0 to 10 ; Do these produce two types which are functionally equivalent (with the same range and operators) but which are incompatible due to being different types? Thanks for the help!
