Internal Error: Sub-system: QSYN, File: /quartus/synth/qsyn/qsyn_cmd.cpp, Line: 1803
Hello dears,I am encountering the same errors, did you mange to solve this issue?I am using Quartus 17.1 and OpenCL SDK for FPGA 17.1
- Patan3 years ago
Hello all,
I am also facing the similar error when I tried to run a basic AND gate program in Quartus 17.1, the tool keep crashing.
FYKI,
Problem Details
Error:
Internal Error: Sub-system: DCALC, File: /quartus/ddb/dcalc/dcalc_bcm_modules_cache.cpp, Line: 110Could not load pdb file - c:/intelfpga_pro/17.1/quartus/common/devinfo/cyclone10gx/ddb_cyclone10gx_io_48_lvds_tile_hps-ss-2p5-100-hs_model
Stack Trace:
0x5d3a3: DCALC_TIMING_MODULES_CACHE::get_model + 0x21d4f (ddb_dcalc)
0x2f2cb: DCALC_TIMING_NETLIST_MANAGER_IMPL::load_model + 0x43 (ddb_dcalc)
0x41631: <lambda_27927aa62a013f38f2f5db62a47234ba>::operator() + 0x71 (ddb_dcalc)
0x2f919: DCALC_TIMING_NETLIST_MANAGER_IMPL::load_corners + 0x49 (ddb_dcalc)
0x2f132: DCALC_TIMING_NETLIST_MANAGER_IMPL::load_timing_corner + 0x4a (ddb_dcalc)
0x30028: DCALC_TIMING_NETLIST_MANAGER::load_timing_corner + 0x14 (ddb_dcalc)
0x4d460: PTI_PHYSICAL_TIMING_API::lazy_load_netlist_type + 0xb8 (tsm_pti)
0x48035: tbb::internal::do_iteration_task_iter<QTL_HASH_SET_LITE_ITERATOR<std::basic_string<char,std::char_traits<char>,std::allocator<char> >,QTL_OPS<std::basic_string<char,std::char_traits<char>,std::allocator<char> > > >,tbb::internal::parallel_for_each_body<<lambda_0f378206216e20c5c02cec778cb5f832>,QTL_HASH_SET_LITE_ITERATOR<std::basic_string<char,std::char_traits<char>,std::allocator<char> >,QTL_OPS<std::basic_string<char,std::char_traits<char>,std::allocator<char> > > > >,std::basic_string<char,std::char_traits<char>,std::allocator<char> > >::execute + 0x1d (tsm_pti)
0x1c1f3: tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all + 0x193 (tbb) at d:\sj\nightly\17.1\240\w64\acds\quartus\extlibs64\tbb\tbb42_20131118oss_altera\src\tbb\custom_scheduler.h:472
0x19afe: tbb::internal::arena::process + 0x18e (tbb) at d:\sj\nightly\17.1\240\w64\acds\quartus\extlibs64\tbb\tbb42_20131118oss_altera\src\tbb\arena.cpp:105
0x16867: tbb::internal::market::process + 0xf7 (tbb) at d:\sj\nightly\17.1\240\w64\acds\quartus\extlibs64\tbb\tbb42_20131118oss_altera\src\tbb\market.cpp:479
0x10eac: tbb::internal::rml::private_worker::run + 0x6c (tbb) at d:\sj\nightly\17.1\240\w64\acds\quartus\extlibs64\tbb\tbb42_20131118oss_altera\src\tbb\private_server.cpp:283
0x1111a: tbb::internal::rml::private_worker::thread_routine + 0x5a (tbb) at d:\sj\nightly\17.1\240\w64\acds\quartus\extlibs64\tbb\tbb42_20131118oss_altera\src\tbb\private_server.cpp:240
0x24f7e: _beginthreadex + 0x106 (MSVCR120)
0x25125: _endthreadex + 0x191 (MSVCR120)
0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
0x526a0: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_fit
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 17.1.0
Build: 240
Edition: Pro Edition
