sukesh
3 years agoInternal Error: Sub-system: CDB_SGATE, File: /quartus/db/cdb_sgate/cdb_sgate_component.cpp, Line: 93
Hi, I am working on Quartus Prime pro 20.3 version. The Device I am working with is Arria10. I am facing the internal error while compiling the project. The Analysis and Synthesis runs initially afte...
RichardT_altera
3 years agoI haven't seen this internal error before. Could you help to share your design .qar file (Project> Achieve Project) that could duplicate this error?
We will need to duplicate the error as without the error duplication from our side, it would be hard to find a workaround/solution.
If possible, try to upgrade to the latest Quartus Pro version 22.4 to check if the issue persists, as a lot of bug has been fixed since then.
I found a similar thread but not sure if it helps.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
- sukesh3 years ago
Hi Richard,
Attaching the archived project for your reference.
