Internal Error: Sub-system: ARES
Problem Details
Error:
Internal Error: Sub-system: ARES, File: , Line: 0
Attemp to assign BCM attribute 'maib_ss_lib_r0_c274.x0.u7_2.hdpldadapt.hdpldadapt_tx_chnl.fpll_shared_direct_async_in_sel'to 2 different values 'FPLL_SHARED_DIRECT_ASYNC_IN_ROWCLK' and 'FPLL_SHARED_DIRECT_ASYNC_IN_DCM'
Stack Trace:
Quartus 0x8f63f: ARES::LAUNCHPAD_IMPL::translate_to(ARES::BCM_SETTINGS*, std::basic_ofstream<char, std::char_traits<char> >*) + 0x1a7 (db_ares)
Quartus 0x8ed84: ARES::LAUNCHPAD_IMPL::translate_to(DBCM_CHIP*, std::basic_ofstream<char, std::char_traits<char> >*) + 0xda (db_ares)
Quartus 0x1cbacd: U2B2_ND_HSSI_ATTR::U2B2_ND_HSSI_ATTR_TRANSLATOR_MODULE::translate(U2B2_CONFIG*, DBCM_CHIP*) + 0x7cb (db_u2b2_core)
Quartus 0xd2183: U2B2_MODULE::translate(U2B2_CONFIG*, DBCM_CHIP*) + 0x51 (db_u2b2_core)
Quartus 0xb7625: U2B2_DIRECTOR::translate(U2B2_CONTEXT const&) const::{lambda(std::pair<QSYM const, U2B2_CONFIG*>)#1}::operator()(std::pair<QSYM const, U2B2_CONFIG*>) const + 0xc3 (db_u2b2_core)
Quartus 0xb7701: tbb::interface9::internal::do_iteration_task_iter<tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<QSYM, U2B2_CONFIG*, QTL_OPS<QSYM, void>, tbb::tbb_allocator<std::pair<QSYM, U2B2_CONFIG*> > >, std::pair<QSYM const, U2B2_CONFIG*> const>, tbb::internal::parallel_for_each_body_do<U2B2_DIRECTOR::translate(U2B2_CONTEXT const&) const::{lambda(std::pair<QSYM const, U2B2_CONFIG*>)#1}, tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<QSYM, U2B2_CONFIG*, QTL_OPS<QSYM, void>, tbb::tbb_allocator<std::pair<QSYM, U2B2_CONFIG*> > >, std::pair<QSYM const, U2B2_CONFIG*> const> >, std::pair<QSYM const, U2B2_CONFIG*> >::execute() + 0x1f (db_u2b2_core)
Quartus 0x27166: tbb::internal::custom_scheduler<tbb::internal::IntelSchedulerTraits>::local_wait_for_all(tbb::task&, tbb::task*) + 0x536 (tbb)
Quartus 0xba254: tbb::interface9::internal::do_group_task_forward<tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<QSYM, U2B2_CONFIG*, QTL_OPS<QSYM, void>, tbb::tbb_allocator<std::pair<QSYM, U2B2_CONFIG*> > >, std::pair<QSYM const, U2B2_CONFIG*> const>, tbb::internal::parallel_for_each_body_do<U2B2_DIRECTOR::translate(U2B2_CONTEXT const&) const::{lambda(std::pair<QSYM const, U2B2_CONFIG*>)#1}, tbb::interface5::internal::hash_map_iterator<tbb::interface5::concurrent_hash_map<QSYM, U2B2_CONFIG*, QTL_OPS<QSYM, void>, tbb::tbb_allocator<std::pair<QSYM, U2B2_CONFIG*> > >, std::pair<QSYM const, U2B2_CONFIG*> const> >, std::pair<QSYM const, U2B2_CONFIG*> >::execute() + 0xf4 (db_u2b2_core)
Quartus 0x1fd68: tbb::internal::arena::process(tbb::internal::generic_scheduler&) + 0x1e8 (tbb)
Quartus 0x1e85b: tbb::internal::market::process(rml::job&) + 0x1b (tbb)
Quartus 0x1aad5: tbb::internal::rml::private_worker::run() + 0x65 (tbb)
Quartus 0x1ad19: tbb::internal::rml::private_worker::thread_routine(void*) + 0x9 (tbb)
System 0x7aa1: (pthread)
System 0xe8c4d: clone + 0x6d (c)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: CentOS release
OS version: 6
Quartus Prime Information
Address bits: 64
Version: 21.1.0
Build: 169
Edition: Pro Edition
- RichardT_altera
I found a similar internal error in the database and saw that it was fixed in Quartus Pro 21.3.
Could you try to upgrade your design to the latest Quartus Pro version 22.4 and see if the issue persists?
Richard Tan
- King22
Download 22.4 still on going ,
- RichardT_altera
May I know does my latest reply helps in resolve your issue?
Richard Tan
- RichardT_altera
Any update on this?
Richard Tan
p.s. Please do expert delay in response due to lunar new year.
- RichardT_altera
As we do not receive any response from you on the previous question/reply/answer that we have provided. I now transition this thread to community support. Please login to https://supporttickets.intel.com, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
