12 years ago
Internal Error in Quartus II 13.1
I am using Quartus II 13.1 in XP 64 and when I try to compile my design I have this error :
Internal Error: Sub-system: VRFX, File: /quartus/synth/vrfx/verific/database/net.cpp, Line: 2541
tmp
Stack Trace:
0xb51ab: VRFX_ELABORATOR::elaborate + 0x5ba9b
0xb4e90: VRFX_ELABORATOR::elaborate + 0x5b780
0xaaa08: VRFX_ELABORATOR::elaborate + 0x512f8
0xab1a5: VRFX_ELABORATOR::elaborate + 0x51a95
0x190222: VRFX_ELABORATOR::operator= + 0x80932
0x1908bc: VRFX_ELABORATOR::operator= + 0x80fcc
0x60316: VRFX_ELABORATOR::elaborate + 0x6c06
0x598fc: VRFX_ELABORATOR::elaborate + 0x1ec
0xd6f93: sgn_clear_check_ip_functor + 0x3a323
0xdac3f: sgn_clear_check_ip_functor + 0x3dfcf
0xdc525: sgn_clear_check_ip_functor + 0x3f8b5
0xa57d4: sgn_clear_check_ip_functor + 0x8b64
0xb5efc: sgn_clear_check_ip_functor + 0x1928c
0xb286a: sgn_clear_check_ip_functor + 0x15bfa
0xb5f4c: sgn_clear_check_ip_functor + 0x192dc
0xba0dd: sgn_clear_check_ip_functor + 0x1d46d
0x10de2: sgn_qic_full + 0x152
0x128ed: qexe_get_command_line + 0x206d
0x1573e: qexe_process_cmdline_arguments + 0x59e
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x1969b: BaseProcessStart + 0x2b
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Full Version
Does anyone can help me please?
Nicolas
    Hi, you can delete the "db" subdir of your project. It often helps.
    I have the solution!
    It was global signals that I don't exclude from synthesis.
    I used global signals in my simulation and I forgot to exclude them from synthesis.
    But I didn't have error messages during synthesis process. I don't know why...
