Intel Quartus Prime Lite version 21.1.1. Error (suppressible): (vsim-12110)
I was using Intel Quartus Prime Lite for a project. I opened a University Program VWF to simulate my project. Once I set up the option "Node finder" and pressed Run Functional Simulation, it fed me back with an error:
Error (suppressible): (vsim-12110) The -novopt option has no effect on this product. -novopt option is now deprecated and will be removed in future releases.
I installed Quartus Prime Lite version 21.1.1, but it did not come with the modelsim_ase. For the simulation to work properly I installed ModelSim 20.1. This solved one problem: Error: Invalid license environment. Application closing.
But then the error aforementioned appeared.
How could I solve this problem from Windows 10?
The Modelsim* - Intel® FPGA Edition (including Starter Edition) will be replaced by the Questa* - Intel® FPGA Edition (including Starter Edition) starting from the Intel® Quartus® Prime Pro Edition Software version 21.3 and Intel® Quartus® Prime Standard/Lite Edition Software version 21.1 onwards. Thus, it is expected that the Quartus Prime Lite version 21.1.1 do not come with the modelsim_ase.
https://www.intel.com/content/www/us/en/support/programmable/articles/000088418.html
Please download the Questa*-Intel® FPGA Edition (including Starter edition) so that it is compatible with the Intel® Quartus® Prime Lite Edition Design Software Version 21.1.1.
You can checkout the forum case below on the solution for the -novopt option error:
Hope it helps.
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
- RichardT_altera
Hope it helps.
Richard Tan
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
- Élan
Hi, Richard.
Sure, I was able to solve the problem with the solutions you gave me.
Thank you so much
- RichardT_altera
Thank you for acknowledging the solution provided. I'm glad to hear that your question has been addressed. Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Thank you and have a great day!
Richard Tan
