ali21
7 years agoIntel HLS link x86-64 failed
Hi, I ran the example in quartus18.0 and it terns out the LNK1107 error C:\intelFPGA_std\18.0\hls\examples\counter>build test-x86-64
i++ -march=x86-64 counter.cpp -o test-x86-64.exe
c:/program fi...
KhaiChein_Y_Intel
7 years agoHi ali21,
1) Are you following the HLS Starting Guide? Did you run the init_hls.bat first? User need to run this *.bat before any compilation as it will setup the environment.
2) Could you check if you have link.exe in c:/program files (x86)/microsoft visual studio 14.0/vc/bin ?
3) This error states that user is adding a 32 bit link file for usage which is incorrect, HLS requires the 64 bit link file. \VC\bin\amd64\link.exe
- ali217 years ago
I did have used 32 bit link file . Thanks very much.
