Intel HLS 17.1 verilog code generation error.
I do not know what you did, that it works well.
But with me it works the same way.
// Generated by Intel(R) HLS Compiler, Version 18.1.0 Build 625
// MODULE hls_aes256_internal
module hls_aes256_internal
input logic clock,
input logic resetn,
input logic clock2x,
output logic done_irq,
// AVS avs_control
input logic avs_control_enable,
input logic avs_control_read,
input logic avs_control_write,
input logic avs_control_address,
input logic [7:0] avs_control_writedata,
input logic avs_control_byteenable,
output logic [7:0] avs_control_readdata,
output logic avs_control_readdatavalid,
// AVS avs_cra
input logic avs_cra_enable,
input logic avs_cra_read,
input logic avs_cra_write,
input logic [1:0] avs_cra_address,
input logic [63:0] avs_cra_writedata,
input logic [7:0] avs_cra_byteenable,
output logic [63:0] avs_cra_readdata,
output logic avs_cra_readdatavalid,
// AVS avs_in_data
input logic avs_in_data_enable,
input logic avs_in_data_read,
input logic avs_in_data_write,
input logic avs_in_data_address,
input logic [127:0] avs_in_data_writedata,
input logic [15:0] avs_in_data_byteenable,
output logic [127:0] avs_in_data_readdata,
output logic avs_in_data_readdatavalid,
// AVS avs_key
input logic avs_key_enable,
input logic avs_key_read,
input logic avs_key_write,
input logic [2:0] avs_key_address,
input logic [31:0] avs_key_writedata,
input logic [3:0] avs_key_byteenable,
output logic [31:0] avs_key_readdata,
output logic avs_key_readdatavalid,
// AVS avs_out_data
input logic avs_out_data_enable,
input logic avs_out_data_read,
input logic avs_out_data_write,
input logic [2:0] avs_out_data_address,
input logic [15:0] avs_out_data_writedata,
input logic [1:0] avs_out_data_byteenable,
output logic [15:0] avs_out_data_readdata,
output logic avs_out_data_readdatavalid
