LKwia
8 years agoIntel HLS 17.1 verilog code generation error.
If I have such a declaration of function: "hls_avalon_slave_component component void hls_aes256(hls_avalon_slave_memory_argument(1) uint8_t *control, hls_avalon_sl...
MuhammadAr_U_Intel
Contributor
8 years agoHi @LKwia
Indeed what you quoted as HLS output is incorrect.
I have tried to create a similar component on my HLS 18.1 Standard Edition Windows 10, I got the correct output (dsee code snippets below).
My suggestion to you will be to update to latest version.
C++ Component Definition:
hls_avalon_slave_memory_argument(32) uint8_t *key,
hls_avalon_slave_memory_argument(16) uint8_t *in_data,
hls_avalon_slave_memory_argument(16) uint8_t *out_data,
int N
) Verilog Output:
// Generated by Intel(R) HLS Compiler, Version 18.1.0 Build 625
// MODULE hls_aes256_internal
module hls_aes256_internal
input logic clock,
input logic resetn,
input logic [31:0] N,
input logic start,
output logic busy,
output logic done,
input logic stall,
// AVS avs_control
input logic avs_control_enable,
input logic avs_control_read,
input logic avs_control_write,
input logic avs_control_address,
input logic [7:0] avs_control_writedata,
input logic avs_control_byteenable,
output logic [7:0] avs_control_readdata,
output logic avs_control_readdatavalid,
// AVS avs_in_data
input logic avs_in_data_enable,
input logic avs_in_data_read,
input logic avs_in_data_write,
input logic [3:0] avs_in_data_address,
input logic [7:0] avs_in_data_writedata,
input logic avs_in_data_byteenable,
output logic [7:0] avs_in_data_readdata,
output logic avs_in_data_readdatavalid,
// AVS avs_key
input logic avs_key_enable,
input logic avs_key_read,
input logic avs_key_write,
input logic [4:0] avs_key_address,
input logic [7:0] avs_key_writedata,
input logic avs_key_byteenable,
output logic [7:0] avs_key_readdata,
output logic avs_key_readdatavalid,
// AVS avs_out_data
input logic avs_out_data_enable,
input logic avs_out_data_read,
input logic avs_out_data_write,
input logic [3:0] avs_out_data_address,
input logic [7:0] avs_out_data_writedata,
input logic avs_out_data_byteenable,
output logic [7:0] avs_out_data_readdata,
output logic avs_out_data_readdatavalid
);Thanks,
Arslan
