LKwia
8 years agoIntel HLS 17.1 verilog code generation error.
If I have such a declaration of function: "hls_avalon_slave_component component void hls_aes256(hls_avalon_slave_memory_argument(1) uint8_t *control, hls_avalon_sl...
HRZ
8 years agoI cannot comment on your HLS problem but the OpenCL compilation is not working because of this error:
C:/Users/user/Desktop/OpenCL_AES/aes256/system/synthesis/submodules/acl_fifo_stall_valid_lookahead.sv Line: 25
Error (10759): Verilog HDL error at aes256_system.v(311): object aes256Encrypt_finish declared in a list of port declarations cannot be redeclared within the module body File: C:/Users/user/Desktop/OpenCL_AES/aes256/system/synthesis/submodules/aes256_system.v Line: 311
Are you using an HDL library in the OpenCL code? I don't see why you would get such error with a standard OpenCL design.
