LKwia
8 years agoIntel HLS 17.1 verilog code generation error.
If I have such a declaration of function: "hls_avalon_slave_component component void hls_aes256(hls_avalon_slave_memory_argument(1) uint8_t *control, hls_avalon_sl...
MuhammadAr_U_Intel
Contributor
8 years agoHi,
I am looking at this thread, I am not sure if I understand you correctly.
Are you asking why HLS generate Verilog code ? or is there any problem in generated code ? Please specify.
HLS is intended to generate the HDL code (Verilog) in this case, that can be used later in Quartus to generate programming file or to integrate with rest of your design.
You might want to take a look at our HLS web page.
https://www.intel.com/content/www/us/en/software/programmable/quartus-prime/hls-compiler.html
Arslan
