Intel FPGA SDK for OpenCL still looking for license files.
When running Quartus through the OpenCL design flow, it works fine when $LM_LICENSE_FILE is unset. I think this is the expected behavior, as it says
- "The Intel® Quartus® Prime Software does not require a license purchase when used as part of the Intel® FPGA SDK for OpenCL™
here
https://www.intel.com/content/www/us/en/software/programmable/sdk-for-opencl/overview.html
However, when $LM_LICENSE_FILE points to a license server where older licenses are present or an older version of the license daemon is running, the flow fails, in our case with
Error (119013): Current license file does not support the 1SG280LN2F43E2VG device. Go to the Self-Service Licensing Center on the Intel FPGA website to manage your licenses (https://mysupport.altera.com/AlteraLicensing/license/index.html).
I'm not sure if it will actually block a valid license when it finds it, but I think the behavior is unfortunate for a tool that is supposed to run without license.
- KhaiChein_Y_Intel
May I know the version of the software and license daemon you are using?
- KhaiChein_Y_Intel
Any updates?
- TKent1
$ aoc -version
Intel(R) FPGA SDK for OpenCL(TM), 64-Bit Offline Compiler
Version 19.1.0 Build 240 Pro Edition
Copyright (C) 2019 Intel Corporation
We recently updated to this license server and daemon, but the problem persists:
$ ./lmutil lmstat -a -c $LM_LICENSE_FILE | grep -E 'INTEL|MASTER'
license server UP (MASTER) v11.16.2
INTEL: UP v11.16.2
Before the license setup was:
license server UP (MASTER) v11.15.1
INTEL: UP v11.15.0
- KhaiChein_Y_Intel
Are you downloading daemon from https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/licensing/daemons.html? The daemon in alterad.
- KhaiChein_Y_Intel
Hi, May I know if you have any updates? Thanks.
