9 years agoIntel FPGA SDK for OpenCL Licensing
I am running into a licensing error when trying to compile my OpenCL kernels using the aoc command. I have the LM_LICENSE_FILE environment variable set to the port@sever that contains the lice...
9 years agoIf you have the same problem on Windows on the same machine, your problem might be some strange incompatibility between the license manager and your network card, or some firewall issue inside your network. I recommend contacting Altera directly; I personally cannot think of any logical explanations.
