9 years agoIntel FPGA SDK for OpenCL Licensing
I am running into a licensing error when trying to compile my OpenCL kernels using the aoc command. I have the LM_LICENSE_FILE environment variable set to the port@sever that contains the lice...
9 years agoAre you sure your license is also valid for OpenCL? OpenCL compilation needs its own specific field in the license file (separate from Quartus license). OpenCL emulation does not need a license and works without a valid OpenCL license.
