9 years agoIntel FPGA SDK for OpenCL Licensing
I am running into a licensing error when trying to compile my OpenCL kernels using the aoc command. I have the LM_LICENSE_FILE environment variable set to the port@sever that contains the lice...
9 years agoI have tried the --report switch and nothing changes running aoc with either -march=emulator or without. Additionally, the -march=emulator switch does not generate a "report" folder. Like mentioned before, running aoc without the -march=emulator switch fails because it was not able to acquire a valid license.
I have updated Quartus, the programming tools, and AOCL to v16.1.2 build 203. I've followed very closing the Getting Started guide so all path and required variables are set. LM_LICENSE_FILE points to the correct port and server that contains the license for the Altera tools including the Intel FPGA SDK for OpenCL and Quartus Prime Pro is licensed correctly in the same manner. Let me know if there would be anything else that I am missing.
