Intel Ampcrypt Module Hierarchy
Yes, this is expected. For some encrypted IP cores, the ability to tap internal nodes is considered a feature, while for others, it is seen as a security vulnerability.
I believe this was discussed years ago, and a potential solution was considered—allowing IP providers to decide whether their signals could be tapped on a customer’s machine. However, due to the complexity and high development costs, this proposal was ultimately rejected or put on hold.
Unless there is a strong business justification, this is unlikely to change, especially for Quartus Standard, which is currently in maintenance mode.
I'm not sure if obfuscation would provide much protection. While it may add a layer of difficulty for reverse engineering, users would still be able to use SignalTap to extract some level of information.
Richard Tan
