11 years ago
Integrating HDL module with Altera OpenCL BSP
I am currently trying to integrate my custom HDL into the OpenCL BSP. I am using a bittware s5_net board. I found that even a simple pass through hdl code does not work. I added some pass through logic (avalon ST single clock fifo) to the "system.qsys" file and added channels to board_spec.xml. The opencl code simply writes to the pass through logic and reads from it.
channel uint inChannel __attribute__((io("rtl_in")));
channel uint outChannel __attribute__((io("rtl_out")));
# define DATA_SIZE 100
__kernel void write_to_rtl(__global uint *restrict input_data)
int offset = 0;
int data = 0;
for(offset = 0; offset < DATA_SIZE; offset++)
data = input_data[offset];
write_channel_altera(outChannel, data);
__kernel void read_from_rtl(__global uint *restrict output_data)
int offset = 0;
int data = 0;
data = read_channel_altera(inChannel);
output_data[offset] = data;
Do I need to add anything else ? I would really appreciate any suggestions on this. I have been trying to debug it for the past few days, trying out various combinations. I did not find anything suspicious in the generated qsys files, although trying to read the autogenerated opencl hdl did not help much.
However, if I just replace my io channels with an opencl channel, it works find. Thus I know that the rest of the code works.
I have attached the generated qsys files, the updated board_spec.xml and my opencl code.
Any suggestions on this would really helpful.
Nilim
