May be i din describe correctly.
Actually i want the led to be used a .1s. When 0.1s, 1st LEDon. 0.2s, 1st and 2nd LEDs on. It continues until 1s 10 LEDs on together. and it rotates.
Currently what i do is i use case statement(as explained above) and reg(as 0.1 counter, reach 10 it reset again)
The problem with this coding is if i have a lot of LEDs(other application). The coding will be consuming.
By the way, does verilog have rotate?
Besides, i see a lot of# number in some book means delay. Is this for test bench or RTL modelling or both?
thanks a lot
